Normal Topic AREA onclick? (Read 3943 times)
pengwin
U2 UniVerse | SB+
AREA onclick?
May 17th, 2006 at 4:44am
Is there a way to add an onclick to the <AREA tag of the map?
like :
TARGET="_self" ALT="" onclick="test(this.href)">
is there something to be added either to the hb or node class?
Thanks.
Re: AREA onclick?
Reply #1 - May 17th, 2006 at 6:39am
You could set the Hyperlink value to "javascript: test(this.href)".
pengwin
U2 UniVerse | SB+
Re: AREA onclick?
Reply #2 - May 17th, 2006 at 6:51am
and for
<AREA SHAPE="RECT" COORDS="261,1277,336,1352"
HREF="#myProcess.aspx?x=250" TARGET="_self" ALT="" onclick="updateDivSrc('fProperties',this.href)">
Re: AREA onclick?
Reply #3 - May 17th, 2006 at 7:41am
We can add an event to the HtmlBuilder which would be raised for each AREA and let you append additional attributes and event handlers to the image areas. Until that's ready, modify your function so that it returns the URL passed as argument; then you could use it like this
HREF="javascript: updateDivs(..., '#yProcess.aspx?x=250')"
pengwin
U2 UniVerse | SB+
Re: AREA onclick?
Reply #4 - May 17th, 2006 at 8:16am
we'll give that a try Smiley ... thanks .. Smiley
pengwin
U2 UniVerse | SB+
Re: AREA onclick?
Reply #5 - May 17th, 2006 at 8:59am
ta - that worked 100% .. look forward to the new addition - perhaps even an attribute.add function so any "other" attrib can be added to the <MAP / <AREA tag/s? Wink
L8rs
Re: AREA onclick?
Reply #6 - May 17th, 2006 at 5:21pm
the control will just give you the tag string for each area so you can append anything there, is that ok ?
pengwin
U2 UniVerse | SB+
Re: AREA onclick?
Reply #7 - May 18th, 2006 at 5:31am
awesome  Grin
