Normal Topic getboxat threshold (Read 4585 times)
p.hannah
getboxat threshold
May 18th, 2006 at 2:23am
Is it possible to implement for boxes a similar feature to that used for arrows, where the getarrowat has a threshold?
p.hannah
Re: getboxat threshold
Reply #1 - May 18th, 2006 at 3:30am
Just thought I'd explain why I'm interested in this, in case there's a better way to deal with the situation.
I want to give feedback to the user during a arrow-manipulation, and need to know whether a particular control-point on an arrow (in particular first and last) is over a particular box.
With the arrows set to snap-to-border, the getboxat(arrow-end-point) work at random, seemingly depending on rounding differences.  So simply making sure that the end-points when snapped-to are absolutely within the boundary would solve my problem.
Anyway, if I'm approaching this in the wrong way, please let me know.
Paul.
Reply #2 - May 18th, 2006 at 6:05am
We can add a SnapThreshold property if that's what you need. It would allow snapping an arrow to the box border even if the arrow's end-point isn't inside the box.
p.hannah
Reply #3 - May 18th, 2006 at 6:22am
No, the snapping is working perfectly.
What I think is the problem is that the snapped-to point might be x=0.99999 on one side and x=1.99999 on the other where the edges of the item runs down at 1.0000 and 2.0000 respectively, which means that on the left side getboxat will return null, and on the right side getboxat will return the box.
This is only subjective and I may be wrong.  But it reliably does this (one side works, one side doesn't and curved edges are seemingly random.)
My first thought was that if I could set an optional parameter in getboxat in the same way as I can currently in getarrowat (it's called maxDist) it might solve the problem.
Paul.
Reply #4 - May 18th, 2006 at 10:38am
I see; ok we'll try to implement that and the groups Z order control by tomorrow.
Reply #5 - May 19th, 2006 at 10:57am
I've emailed updated dlls to the address you have registered with us. That version adds a GetBoxAt(point, threshold) method to let you find a box at some distance from a point. Enable the SortGroupsByZ property to have group items sorted by their Z order when they are drawn.
