Normal Topic Form.fc.LoadFromString Unsupported Method (Read 2946 times)
alfadata
Jun 7th, 2006 at 8:24pm
Object doesn't support property or method: 'Form.fc.LoadFromString'
When simply running the sample ClientSvr_VB application the HTML code does not seam to be retrieving the correct "fc" object.
We believe we have followed the steps correctly and have the dll appropriately licensed for run-time.
Windows XP, Visual Studio.NET 2003, FlowChartX .NET
Re: Form.fc.LoadFromString Unsupported Method
Reply #1 - Jun 8th, 2006 at 8:21am
That usually means IE could not load the flowchart.net dll or could not download it at all. The problem might happen because by default IIS tries to execute dlls instead of sending them to the browser when it gets a GET request for a dll file. Change the IIS Execute Permissions in the Home Directory property page from "Script and Executables" to "Script only", that should allow IE download the dll.
ScubaNet
Reply #2 - Jul 3rd, 2007 at 7:07am
I have exactly the same problem.
I've tried to put "Script Only" in IIS without success.
is there another way to resolve this issue?
Reply #3 - Jul 3rd, 2007 at 8:44am
Can you see a Flowchart.NET.dll copy in the "temporary internet files" folder after trying to load the page?
ScubaNet
Reply #4 - Jul 3rd, 2007 at 9:30am
yes, i can see flowchart.Net.DLL in temporary internet files.
I can also see this dll in Global Assembly Cache when I run "gacutil /ldl"
Reply #5 - Jul 3rd, 2007 at 10:22am
Have you created a ".licenses" file and referenced it from a LINK tag? You might check the ClientSvr sample project for details.
<link href="main.aspx.licenses" rel="licenses">
ScubaNet
Reply #6 - Jul 3rd, 2007 at 10:31am
I've made a new test and now it works.
I've delete Global Assembly cache before and after it has worked.
Thanks for help.
