Normal Topic How to Print without Print Dialog box for Multiple (Read 2200 times)
james
Guest
Jun 20th, 2006 at 6:09am
In Print() of FlowChart, the Print Dialog appears for Printer  selection. But we want to print without invoking the dialog box, Is there a possibility [without using Print(PrintDocument)].  if yes please guide...
Thanks in advance!
Re: How to Print without Print Dialog box for Mult
Reply #1 - Jun 20th, 2006 at 8:26am
You can skip the print dialog only by specifying a printer using the PrintDocument parameter. Is there any specific reason you don't want to use that overload of the Print method ?
Reply #2 - Jun 20th, 2006 at 8:30am
E.g. this will print to the default printer without showing any dialog:
fc.Print(new PrintDocument());
james
Guest
Reply #3 - Jun 20th, 2006 at 9:28am
Its works fine. Thank you very much.
