Normal Topic Couldn't get design time license (Read 3121 times)
maranello
Jun 26th, 2006 at 10:25pm
Our company purchased the standard edition of Flowchart.NET a few days ago. However, I am facing this problem.
I can add the item on the toolbox in visual studio 2003, but when i try to create a flowchart on a winform, i get this error:
"An exception occured while trying to create an instance of MindFusion.FlowChartX.FlowChart. The exception was "Couldn't get design time license for "MindFusion.FlowChartX.FlowChart".
I have practically tried everything, i tried adding it separately to references tree, but it didn't work.
From time to time I also get the following error:
"Request for the permission of type System.Security.Permissions.RegistryPermission, mscorlib, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 failed"
We use .NET 1.1 and C#.
Thank you for your time.
maranello
Re: Couldn't get design time license
Reply #1 - Jun 26th, 2006 at 10:26pm
I also tried going to Administrative Tools, .NET 1.1 wizard, and give fully trust to .dll files and change security settings, but that didn't help.
Reply #2 - Jun 27th, 2006 at 5:41am
The design-time key is read from the registry, so if FlowChart.NET does not have a CAS RegistryPermission, you won't be able to use the control. Make sure your logon account has permissions to read the following registry ky:
HKEY_LOCAL_MACHINE\SOFTWARE\MindFusion Limited\ComponentLicenses
Also try assigning the Everything permission set to the Flowchart.NET assembly, from our experience the FullTrust set seems more restricted.
maranello
Reply #3 - Jun 27th, 2006 at 10:44am
alright, i did what you said, it didnt work. I also replied your e-mail, i guess e-mail is faster so i ll stop posting here.
