Normal Topic Adnode did not displayed node (Read 3350 times)
tj
Jun 28th, 2006 at 3:04pm
I am evaluate the FC at this time.
The flowchart component is contained in one of  the splitted pane which also a control in a tabpane.
I use the telephony codes and just put  the FC inside the splitted pane. But when I select the icon on the imagelist and then click the FC doc to add the node: the node is not displayed. Thru debugging I see that the FC has the object in its objects collection.
What change should I make so that the FC shows the added nodes ( The node is an icon with label).
Re: Adnode did not displayed node
Reply #1 - Jun 28th, 2006 at 3:42pm
Could you scroll around to see if the node isn't placed at another position ? There might be an error in some coordinate conversion code in that example if the flowchart is not at the top-left-most part of the form.
tj
Reply #2 - Jun 28th, 2006 at 4:14pm
I check and see that all the box has the x and Y in the display range.
The FC dock was set to fill and there is not scrollbar.
Do I need to do any coordinate conversion before using  the event X&Y??
Reply #3 - Jun 28th, 2006 at 4:48pm
Does the box appear if you create it at point (0, 0) ? What code do you use to create the box ?
tj
Reply #4 - Jun 28th, 2006 at 7:01pm
Even the first instruction box did not show up.
This code is the same as in telephony except the flowchart is belong to a tabpane and the its dock is set to fill.
private void topology_Load(object sender, System.EventArgs e)
           InitializeComponent2();
           lvTypes.Items[0].Selected = true;
           fcx.DocExtents = new RectangleF(0, 0, 2000, 3000);// pixels
           fcx.ScrollTo(0, 0);
           // show instructions box
           Box ib = new Box(fcx);
           ib.BoundingRect = new RectangleF(10, 10, 250, 50);
           ib.Text = "To create a node, select node type from the list on the right, then " +
               "single-click in the drawing surface on the left.";
           ib.Tag = 42;
           ib.Brush = new MindFusion.FlowChartX.LinearGradientBrush(
               Color.White, Color.Gold, 30);
           fcx.Add(ib);
tj
Reply #5 - Jun 28th, 2006 at 7:44pm
I did change the x and y to 0 but the FC still did not display the create not. In the debug mode, teh Boxes collection in  the FC has the created boxes.
Any idea?
private void createNode(int type, float x, float y)
           Box atcm = null;
           Table tbl = null;
           Group g = null;
           //Box node = fcx.CreateBox(x - 16, y - 16, 34, 48);
           Box node = fcx.CreateBox(0, 0, 34, 48);
           node.Transparent = true;
           node.EnabledHandles = Handles.Move; // no resizing
           node.Tag = type;
Reply #6 - Jun 29th, 2006 at 4:42am
With Transparent = true only the Image and Text of a box are displayed. Are these properties set anywhere? Could you email me your test project?
