Normal Topic Image in a Appointment (Read 5163 times)
Jerome Mace
Jul 6th, 2006 at 8:29am
How can I view an icon in an appointement. The following code doesn't run ???
Calendar1.ImageList = XXXX
Dim oAppointmentAs New Appointment
oAppointment.StartTime = ...
oAppointment.EndTime =...
oAppointment.ImageIndex = 1
Calendar1.Schedule.Items.Add(oAppointment)
Re: Image in a Appointment
Reply #1 - Jul 6th, 2006 at 9:22am
Images are currently only drawn for items in the timetable view. To associate an image with an item, use either Item.Style.Image or Item.Style.ImageIndex with ImageList associated with the Calendar control.
item.Style.Image = image;
or
item.Style.ImageIndex = 1;
calendar.ImageList = imageList;
Item.ImageIndex is deprecated because the item appearance should depend solely on its style. We appologize we forgot to mark this out throughout the documentation.
Jerome Mace
Reply #2 - Jul 7th, 2006 at 4:57am
Thanks for your code, but which format of image did I use for transparency.
I try with ICO (result = Black background) or GIF (result = White background).
Reply #3 - Jul 7th, 2006 at 7:01am
You are correct, the .NET Compact Framework seems to discard transparency in images. We will add a property which would enable you to specify your own colors as transparent (so called color keys) in the next release.
