Normal Topic Displaying appt items without overlap (Read 2835 times)
Brian O'Neil
Guest
Jul 13th, 2006 at 6:13pm
Is it possible to display the appointment items in the timetable view to only draw the actual time of the appointment instead of filling the whole section of the timetable?  Meaning if have an two appointments that are 10 minutes one starting at 11:00 and one at 11:15 and the scale of the timetable is 30 minutes that they both draw within the same timetable area without offsetting and having one be to the side of the other one?
When we have a large number of short appointments on a schedule and it is at the 30 minute scale in the timetable view it becomes very difficult to read because they are all offset from the other ones even though none of them actually overlap.
Thanks for any help with this,
-Brian O’Neil
Re: Displaying appt items without overlap
Reply #1 - Jul 14th, 2006 at 6:46am
Yes, this will be available in the next release of Planner.NET. It is actually already implemented and my colleagues will contact you by e-mail to send you a download link. In order to use this feature, you have to add the following code:
calendar.TimetableSettings.ShowPadding = State.Disabled;
This will make items appear exactly as long as they actually are. For example 10 minute items will no longer occupy the whole 30 minute cell.
Brian O'Neil
Guest
Reply #2 - Jul 17th, 2006 at 12:48pm
Thanks for the quick response.  I got the email with the prerelease and will test it out.
