I am using Flowchart.net version 4.0.3.30382 in a user control.
Whenever I try a box near or out of the bounds of the flowchart I get the follow error that bubbles up to the main application:
Parameter not valid.
This is an unhandled condition. The full abend info that I get is:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Parameter is not valid.
at System.Drawing.Drawing2D.GraphicsPath.AddArc(Single x, Single y, Single width, Single height, Single startAngle, Single sweepAngle)
at MindFusion.FlowChartX.Utilities.getRoundRect(Single x, Single y, Single width, Single height, Single r)
at MindFusion.FlowChartX.Box.Draw(Graphics g, Boolean shadow)
at MindFusion.FlowChartX.FlowChart.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase:
file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------
System.Drawing
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Web.Services
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Configuration
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.Practices.EnterpriseLibrary.ExceptionHandling
Win32 Version: 2.0.0.0
CodeBase:
file:///C:/vssMerchSystemsSOA/Projects/AIM/Source%20Code/AIMShell/AIM.Shell/AIMShell/bin/Debug/Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.DLL
System.Xml
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
gbu58wee
Assembly Version: 1.0.0.0
CodeBase:
rxawbz6p
CodeBase:
bpryqzo4
CodeBase:
FlowChart.NET
Assembly Version: 4.0.3.30382
Win32 Version: 4.0.3.30382
CodeBase:
file:///C:/vssMerchSystemsSOA/Projects/AIM/Source%20Code/AIMShell/AIM.Shell/AIMShell/bin/Debug/FlowChart.NET.DLL
6sif9eq2
CodeBase:
