Normal Topic Print Preview (Read 2644 times)
snapdragon
Print Preview
Jul 28th, 2006 at 2:11am
I am using calendar.dll version 4.0.2357.24859.
For some reason whenever I tried to do Print Preview or Print, the application comes up with this error:
"An unhandled exception of type 'System.Runtime.InteropServices.SEHException' occurred in system.windows.forms.dll
Additional information: External component has thrown an exception."
This used to work fine in version 3.0.
Is there anything I can do to fix this?
Thanks.
Re: Print Preview
Reply #1 - Jul 28th, 2006 at 9:19am
Can you uninstall this version of the control and reinstall 3.0 to see if this problem will occur again? Can you also check whether you can print and preview from other applications, specifically other .NET programs, if you have available?
Thank you,
snapdragon
Re: Print Preview
Reply #2 - Aug 2nd, 2006 at 11:35pm
Hi Meppy,
Strangely enough, when I re-installed v3, it gave me the same error.
Other .Net apps print and preview without any problems.
One other interesting thing, the Demo.exe that comes with Plannet 4.0 can actually print preview and print.
Am I missing something?
Re: Print Preview
Reply #3 - Aug 3rd, 2006 at 7:04am
Is it possible to send me the application that causes this malfunction through e-mail? I really can'y think of something that might cause the problem if the Demo program prints fine.
