Normal Topic LayeredLayout positioning (Read 2711 times)
boekhocg
Guest
Aug 14th, 2006 at 3:52pm
I'm in the process of evaluating FlowChart.net.
Say for example I have 4 nodes but only 2 have links (related). I'm using the LayeredLayout and it positions them in the following manner:
a-->b  c-->d
Is there a way to have it position all nodes that don't have a parent to the left like the follwing:
a-->b
c-->d
Thank you for your help
Re: LayeredLayout positioning
Reply #1 - Aug 14th, 2006 at 6:04pm
At this time that's hard-coded; independent graphs in the diagram are always positioned in a row from left to right. We can add a new property that will let you order the graphs in a column.
boekhocg
Guest
Reply #2 - Aug 16th, 2006 at 1:09pm
I think that would be a very good property to have. I large diagram would look much nicer if I can place all nodes that don't have a parent on the left hand side above each other. (FYI: I'm using horizontal layering from left to right)
Thank you,
boekhocg
Reply #3 - Dec 6th, 2006 at 5:43pm
Hi, Was the following request/issue added int the latested 4.2.2 release by any chance?
Thank you,
boekhocg
boekhocg
Reply #4 - Dec 6th, 2006 at 6:17pm
I see that it was added in version 4.2.1 using the LayeredLayoud.MultipleGraphsOrientation attribute.
Thank you!
boekhocg
