Normal Topic Reverse Engineering of Database (Read 2627 times)
Rahul Jain
Guest
Aug 31st, 2006 at 6:43am
I would like to create my own Reverse Engineerng module using this control. I would like to have ability to create the tables and create the relations from the Database.
Has anybody done something like this. ? I need where do i start ? and How do I create the relations between tables using VB.
I will be using VB6.
Rahul
Re: Reverse Engineering of Database
Reply #1 - Aug 31st, 2006 at 6:55am
The DBDesign sample project has an "Import" command that imports the schema of a database. That function is incomplete - it imports only the tables, but not the relations. I believe the .NET 2 DataSet object will let you import relations too.
Create a relation between Flowchart.NET tables by calling the
fc.CreateArrow(Table, int, Table, int)
overload of the CreateArrow method or
fc.Add(new Arrow(Table, int, Table, int))
« Last Edit: Aug 31st, 2006 at 9:08am by Stoyo »
Rahul Jain
Guest
Reply #2 - Sep 1st, 2006 at 10:25am
Thanx a lot.. this gives me a head start.
Reply #3 - Sep 2nd, 2006 at 7:56am
Sorry, I did not notice this question was about FlowChartX/ActiveX. Only the FlowChart.NET DBDesign example shows how to import a DB schema, using ADO.NET. Anyway that's probably done in a similar way with the classic ADO, so you could check the sample installed with our .NET control:
https://mindfusion.eu/FCNetDemo.zip
With FlowChartX you can create relations between tables using the CreateRelation method.
