Normal Topic Image with AnchorPoints (Read 2049 times)
Jake
Dude, Your Getting a Dell!
Sep 15th, 2006 at 6:42pm
Good day once again. I was looking for the best solution or practice using your control to display an image and in my case this is a switch and I would like to specify anchor points of course where the switch ports are: much like the way you can do it in Visio by creating a stencil from a image.
I have been stuck on this for a few hours trying differnt solutions but need a slight push from a more experienced user using this control.
Any help or push in the right direction would be great!
Jake
Re: Image with AnchorPoints
Reply #1 - Sep 15th, 2006 at 7:24pm
OK I think I finally got it to work.
I am creating a Box and inserting the image into the box and then creating an anchor collection with my anchor points.
It was just trial and error until I got the anchor points to fit where I needed. As always trying to make it more complicated then needs to be... Smiley Let me know if there is a better way?
Reply #2 - Sep 15th, 2006 at 7:28pm
Good day,
Here is a simple tool that might help - double click where you need achor points to get their coordinates:
https://mindfusion.org/_samples/AnchorEditor.zip
« Last Edit: Sep 16th, 2006 at 7:15am by Stoyo »
Reply #3 - Sep 15th, 2006 at 7:31pm
Oh, you have replied to yourself while I was uploading the sample... Anyway you can load the image in the picture box on that form, then run the sample, and double-click inside the box to get the anchor point coordinates.
« Last Edit: Sep 16th, 2006 at 7:18am by Stoyo »
