Normal Topic how refer to table location in DB design sample (Read 1672 times)
gokul
Sep 18th, 2006 at 2:57am
I am using flowchart.Net sample DBdesing and using Assemblies for .NET 2.0.
in this sample there is inbuild function Arrange
ex. tl.Arrange(fc) and u have used it in DBdesign for arranging tables.
insted of arranging tables in one line i want to arrange tables in my own manner. so i made follwing changes but its not working.i m sending my source code.second thing i have removed tl.arrange(fc) and made follwing changes in DBdesing
'Plese note some line have commented in sample code.code has been developed in .net 2005
Dim cf As ConnectionForm = New ConnectionForm()
   Dim x, y, tblcount, wdth, hgt As Integer
   Dim tbl As Table
   x = 250
   y = 150
   wdth = 100
   hgt = 120
   tblcount = 1
   cf.tbConnect.Text = _
    "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=D:\db\swadesh.mdb;Persist Security Info=False;"
   If cf.ShowDialog() <> System.Windows.Forms.DialogResult.OK Then Return
   Try
  Dim cn As OleDbConnection = New OleDbConnection
  Dim schemaTable As DataTable
  ' connect using specified connection string
  cn.ConnectionString = cf.tbConnect.Text
  cn.Open()
  ' retrieve schema information about tables.
  ' because tables include tables, views, and other objects,
  ' restrict to just TABLE in the Object array of restrictions.
  schemaTable = cn.GetOleDbSchemaTable(OleDbSchemaGuid.Tables, _
     New Object() {Nothing, Nothing, Nothing, "TABLE"})
  'iterate tables
  Dim i As Integer
  For i = 0 To schemaTable.Rows.Count - 1
     If tblcount = 1 Then ' parent table
     tbl = New Table(fc.CreateTable(x, y, wdth, hgt))
     x = x + 150
     ElseIf tblcount Mod 2 = 0 Then 'right side tables
     tbl = fc.CreateTable(x, y, Width, Height)
     'tbl.FitSizeToImage()
     x = x - 300
     ElseIf tblcount Mod 2 <> 0 Then 'left side table
     tbl = fc.CreateTable(x, y, 100, 120)
     y = y - 125
     End If
     fc.Add(tbl)
     'tbl.
     tbl.Caption = schemaTable.Rows(i).ItemArray(2).ToString()
     tbl.BoundingRect = New RectangleF(0, 0, 35, 50)
     ' get columns
     Dim cmd As OleDbCommand = New OleDbCommand
     Dim tblInfo As DataTable
     Dim reader As OleDbDataReader
     ' retrieve schema from the table into a DataReader
     cmd.Connection = cn
     cmd.CommandText = "SELECT * FROM " + tbl.Caption
     reader = cmd.ExecuteReader(CommandBehavior.KeyInfo)
     ' Retrieve column schema into a DataTable.
     tblInfo = reader.GetSchemaTable()
     tbl.RedimTable(2, 0)
     ' for each field in the table...
     Dim r As Integer = 0
     Dim field As DataRow
     For Each field In tblInfo.Rows
     tbl.AddRow()
     ' that's the name of the columns
     tbl(0, r).Text = field(0).ToString()
     ' that's a .NET type, not DB one; skip 'System.'
     Dim dotnetType As String = field(5).ToString()
     tbl(1, r).Text = dotnetType.Substring(7)
     r += 1
     Next field
     ' Always close the DataReader and connection.
     reader.Close()
     tblcount = tblcount + 1
  Next i
  ' explicitly close - don't wait on garbage collection.
  cn.Close()
  ' TODO: read relations
  'Dim tl As MindFusion.FlowChartX.LayoutSystem.TreeLayout = _
  'New MindFusion.FlowChartX.LayoutSystem.TreeLayout
  'tl.NodeDistance = 80
  'tl.Arrange(fc)
   Catch ex As Exception
  MessageBox.Show(ex.Message)
   End Try
    End Sub
Re: how refer to table location in DB design sampl
Reply #1 - Sep 18th, 2006 at 6:14am
What exactly is not working - loading the tables or arranging them? Could you post a screenshot showing what the layout should look like?
« Last Edit: Sep 18th, 2006 at 3:24pm by Stoyo »
gokul
Reply #2 - Sep 19th, 2006 at 3:02am
i found another way to solve my problem thanks
looking forward for further support
