Normal Topic Transparency (Read 1063 times)
joshua
Transparency
Sep 19th, 2006 at 11:24pm
The flowchart control throws an exception when trying to set its backcolor to transparent.  Is there away around this???
Cheers.
Re: Transparency
Reply #1 - Sep 20th, 2006 at 6:07am
It is the base Control class that throws the exception. The BackColor article in MSDN states: "The BackColor property does not support transparent colors unless the SupportsTransparentBackColor value of System.Windows.Forms.ControlStyles is set to true." So you must use the Control.SetStyle method to enable the SupportsTransparentBackColor bit.
SetStyle is a protected method in Control, so you will have to define a class that inherits FlowChart to get access to the method.
We've never tried that, so I cannot guarantee it will work...
