Normal Topic TreeLayout & Group (Read 1386 times)
Jake
Dude, Your Getting a Dell!
TreeLayout & Group
Oct 6th, 2006 at 3:03pm
Good Day,
I am stacking several boxes one on top of another and then grouping them together with the bottom box of the stack the main object. However, when using the treelayout it will rearrange my group horizontally when I need them to stay stacked. I have tried setting the ‘IgnoreLayout’ on the boxes but then of course the treelayout will not layout the group in the tree and I have other boxes on top of my group as a result of the layout. I need to use the treelayout but need my group to stay stacked.
Any help to this solution would be greatly appriciated. And should you need screen shots of the problem, please let me know.
Thanks once again for the greate support you are providing your customers!
Jake
Jake
Re: TreeLayout & Group
Reply #1 - Oct 6th, 2006 at 3:22pm
Another tid-bit. If I move the group everything will return to the stack. However would be nice not to have to move the group to get it to display right.
Jake
Reply #2 - Oct 6th, 2006 at 3:50pm
Good day,
Instead of IgnoreLayout, try how that will work with the TreeLayout.KeepGroupLayout property set to true.
