Normal Topic Box MouseHover Event? (Read 2268 times)
Jake
Dude, Your Getting a Dell!
Oct 11th, 2006 at 5:09pm
Good Day,
I need to display a details dialog/tooltip when a user hovers over a box. I was hoping that I could use formated text in the tooltip but with no such luck. So now I am trying to figure out what Flowchart event I can tap into to let the application know that a user is hovering over a box.
Any help would be super!
Jake
Re: Box MouseHover Event?
Reply #1 - Oct 11th, 2006 at 5:53pm
Add a Timer control to your form, set its interval, and handle the following events:
private void fc_MouseMove(object sender, System.Windows.Forms.MouseEventArgs e)
  hoverTimer.Stop();
  hoverTimer.Start();
private void hoverTimer_Tick(object sender, System.EventArgs e)
  hoverTimer.Stop();
  Point clientPoint = fc.PointToClient(MousePosition);
  PointF docPoint = fc.ClientToDoc(clientPoint);
  Box box = fc.GetBoxAt(docPoint);
  if (box != null)
    box.Text += "beep ";
mjweyland
Reply #2 - Apr 9th, 2007 at 5:59pm
Is this box.mousehover event handling something that will be available in future releases of the tool?
Reply #3 - Apr 10th, 2007 at 3:25am
We can add some Hover events if you wish so Smiley
