Normal Topic Deleting a group (Read 1925 times)
ampersand
Deleting a group
Oct 24th, 2006 at 11:54am
I created a master object of type box and attached several controlHosts to it programmatically.
When the user deletes the box I want the attached objects to be removed also.
What is the most efficent way to do this?
I used BoxDeleting as my starting point, but am unsure how I should delete con controlHosts
Dirk
Re: Deleting a group
Reply #1 - Oct 24th, 2006 at 12:08pm
After attaching the controls, set
box.SubordinateGroup.AutoDeleteItems = true;
ampersand
Reply #2 - Oct 24th, 2006 at 2:10pm
it's so easy when you know where to look for  Grin
Dirk
Reply #3 - Oct 25th, 2006 at 5:15am
