Normal Topic Overview Question (Read 2540 times)
just2click
Go Sharks Go
Overview Question
Oct 31st, 2006 at 8:45am
Hi again folks,
I'm trying to figure out how to better use the overview control.
My problem is this, when the user expands a node sometimes the full graph layout exceeds the actual graph display. Once this happens I'd like to move the overview box so that the expanded box would be in the middle of the overview.
I'm not sure how to obtain the current overview location so I can test if the current box is visible within the overview box or not.
Any ideas?
Dror
Re: Overview Question
Reply #1 - Oct 31st, 2006 at 9:27am
Hi Dror,
At this time there isn't any programmatic control provided over the Overview viewport position. We can implement an Overview.BringIntoView method (similar to the flowchart's one) in the next version.
just2click
Go Sharks Go
Reply #2 - Oct 31st, 2006 at 9:42am
Thanks Stoyo.
What I did up until now is play around with the FC ScrollX and ScrollY properties.
I'd like to create the effect of centrlizing the view around the box that was expnded (for example).
I see that the overview control moves accordingly.
Is there a way I can manipulate the Scroll properties? I have a problem calculating the actual position of boxes that are out of view.
Thanks again,
Dror
Reply #3 - Oct 31st, 2006 at 11:40am
At this time there isn't any method available to let you change the overview scroll position.
Assuming everything is measured in pixels, you can set the flowchart's ScrollX = (box.Left + box.Right - flowChart.Width) / 2, and similar for Y, to center the flowchart's view on a box. However, I am not sure if the overview will automatically follow the flowchart.
