Normal Topic Rotating boxes, but not the box.text (Read 4611 times)
Bas
Oct 23rd, 2006 at 5:12am
Is it possible to be able to rotate a box, but not the box.text string with it? I like this rotating feature, but if the text is also rotated it reduces the readability for the user.
Re: Rotating boxes, but not the box.text
Reply #1 - Oct 23rd, 2006 at 7:36am
Set Box.RotateContents = false.
Bas
Reply #2 - Oct 24th, 2006 at 9:10am
Ok, you're right Wink but let me clarify.. I have a picture in the box, which I would like to be able to rotate. If RotateContents is set to false, the box rotates, but not the picture.
What I was looking for was a way to be able to rotate the box (with contents, so the picture), but not the text.
Reply #3 - Oct 24th, 2006 at 10:13am
You might do that using groups, as described here:
http://mindfusion.org/cgi/Forum/YaBB.pl?board=fcx_disc;action=display;num=116130...
Bas
Reply #4 - Oct 25th, 2006 at 6:14am
Aha I see. This would work, but a new box property would be more elegant. At least it would save the overhead of having two instances per box instead of one.
Reply #5 - Oct 27th, 2006 at 8:33am
It seems that will be a popular feature, so we will add a RotateText property,
Bas
Reply #6 - Oct 27th, 2006 at 11:12am
You guys rock 8)
Thumbs up for the great support.
Reply #7 - Oct 30th, 2006 at 11:34am
This version adds a RotateText property:
https://mindfusion.org/_temp/rottext.zip
RotateText is not yet serialized when you save a diagram file, because we update the file format only for official new versions.
The dll is an evaluation build - send me an email if you wish to receive the licensed build.
