Page Index Toggle Pages: 1 [2] 3  Send TopicPrint
Very Hot Topic (More than 25 Replies) clipboard and ControlHost (Read 16273 times)
ampersand
Re: clipboard and ControlHost
Reply #15 - Nov 21st, 2006 at 2:26pm
Excellent!
Thanks for your help
Dirk
ampersand
Reply #16 - Nov 21st, 2006 at 3:46pm
I just tested the new code and only got partial success:
Bullets and Alignment are now working, but not FontStyle (bold, italic) FontSize and FontFamily.
See here
Dirk
Reply #17 - Nov 22nd, 2006 at 6:06am
Strange, that works fine here. Do you still handle the CopyHostedControl event?
ampersand
Reply #18 - Nov 22nd, 2006 at 6:55am
No, I removed it.
Should I leave it in?
Dirk
Reply #19 - Nov 22nd, 2006 at 8:27am
Nope, it should work without the event. Could you post the Rtf contents here?
ampersand
Reply #20 - Nov 22nd, 2006 at 8:48am
Here's the RTF just before btChart.CopyToClipboard(false)
Quote:
"{\\rtf1\\ansi\\ansicpg1252\\deff0{\\fonttbl{\\f0\\fnil\\fcharset0 Arial;}{\\f1\\fnil\\fcharset2 Symbol;}}\r\n\\viewkind4\\uc1\\pard\\lang1031\\fs20  fds \\ul\\b afd \\ulnone\\b0\\i fdsafdsa \\i0\\fs28 fdsafds \\fs20 afdsa fd\\par\r\ns fdsa \\par\r\n\\pard\\qr fdsa fdsafdsaf\\par\r\n\\pard{\\pntext\\f1\\'B7\\tab}{\\*\\pn\\pnlvlblt\\pnf1\\pninde
nt0{\\pntxtb\\'B7}}\\fi-300\\li300  fds af\\par\r\n{\\pntext\\f1\\'B7\\tab} fdsaf\\par\r\n}\r\n"
and here, right before btChart.PasteFromClipboard(10, 10);
If you need RTF from other locations too, just tell me
Dirk
Reply #21 - Nov 22nd, 2006 at 9:31am
This works fine when copying plain RichTextBox controls. Maybe some property in your extended control clears the formatting when set? If the flowchart calls that property setter after the Rtf property one, the formatting will be lost. Try setting Rtf from the copy event again, just to be sure that Rtf is the last property assigned to.
ampersand
Reply #22 - Nov 22nd, 2006 at 10:48am
Hi Stoyo,
I fear I didn't exactly understand what you want me to do.
Quote:
Maybe some property in your extended control ..
With extended Control do you mean my extended FlowChart control? If so, I've only overriden IsInputKey, so this shouldn't be a problem, right?
What do you mean with setting Rtf? Right now I do nothing with Rtf while copying and pasting.
Should I copy the content of RTF in my copytoClipboard method to a variable and set it again when pasting?
Here's my copy code:
private void kopierenToolStripMenuItem_Click(object sender, EventArgs e)
  if (btChart.Selection.Objects.Count == 1)
    if (btChart.ActiveObject.GetType() == typeof(Box))
    else if (btChart.ActiveObject.GetType() == typeof(ControlHost))
        if (((btChart.ActiveObject as ControlHost).Control as MERichTextBox).Focused)
        else
          btChart.CopyToClipboard(true);
I removed all unnecessary lines.
Dirk
Reply #23 - Nov 22nd, 2006 at 11:41am
I mean you inherit from the RichTextBox control, right? If you add some properties to your class, and any of them sets Lines or Text of the base RichTextBox class, they might clear the formatting if their values are copied after the Rtf value.
Now FlowChart.NET uses reflection to copy all properties from value and string types in the order returned by the reflection API. E.g. it used to copy first Rtf, and then Text, but setting Text has the side effect of loosing the formatting tags. So we added some code to skip the Text and Lines properties of RichText controls, and now copy&paste works fine in our tests.
Now if there is another property in your RichText-inherited class that coud clear the formatting, FlowChart.NET doesn't know about it and might set its value after the Rtf's one.
ampersand
Reply #24 - Nov 22nd, 2006 at 12:23pm
okay, understood.
As far as I can see there are no new properties within the inherited Richtextbox that could set Text, Lines or RTF besides
protected override CreateParams CreateParams.
I don't know if this is causing the problem.
But I still need to know where I should re-set Rtf as you said ("Try setting Rtf from the copy event again"). Just before PasteFromClipboard RTf is still the same as before copying. So I am wondering where or when I should re-set RTF.
Sorry for taking so much of your time Smiley
Dirk
Reply #25 - Nov 22nd, 2006 at 12:45pm
Set Rtf in the CopyHostedControl event handler. The event is raised just after FlowChart.NET copies the control's properties. So probably in that moment the clone's formatting will be already lost . But then if you copy Rtf from the original, the formatting should be restored.
ampersand
Reply #26 - Nov 22nd, 2006 at 1:18pm
hmm, no success:
Here's the source RTF of a sample RichTextBox when running through CopyHostedControl when the ControlHost is copied:
Quote:
"{\\rtf1\\ansi\\deff0{\\fonttbl{\\f0\\fnil\\fcharset0 Arial;}}\r\n\\viewkind4\\uc1\\pard\\tx300\\tx600\\tx900\\tx1200\\tx1500\\lang103
1\\fs20 DDD \\b\\fs20 EEE \\b0\\fs20 FFF\\par\r\n}\r\n"
And here's the destination RTF right after running through CopyHostedControl  when the Controlhost is pasted
Quote:
"{\\rtf1\\ansi\\ansicpg1252\\deff0{\\fonttbl{\\f0\\fnil\\fcharset0 Arial;}}\r\n\\viewkind4\\uc1\\pard\\tx300\\tx600\\tx900\\tx1200\\tx1500\\lang103
1\\fs20 DDD \\b EEE \\b0 FFF\\par\r\n}\r\n"
Both are different. So it seems the rtf is not copied correctly.
Here's the source of the CopyHostedControl
private void btChart_CopyHostedControl(object sender, CopyHostedControlEventArgs e)
MERichTextBox src = e.Source as MERichTextBox;
MERichTextBox dst = e.Destination as MERichTextBox;
if (src != null && dst != null)
dst.Rtf = src.Rtf;
Dirk
Reply #27 - Nov 22nd, 2006 at 5:39pm
Ok, please email me the latest version of your RichTextControl dll.
Reply #28 - Nov 23rd, 2006 at 11:39am
Hi Dirk,
Strange, but copy & paste works fine with your control in our test app. Are you sure your project correctly references the very-last dlls I sent you?
ampersand
Reply #29 - Nov 23rd, 2006 at 11:51am
At least it's good to hear that it is working on your side. So the error must be somewhere else:
I use the following dll-Versions
flowchart.net.dll 4.2.1.29339
ruler.dll 4.2.1.29358
Dirk
