Normal Topic Multiple anchor points (Read 3276 times)
Alex
Nov 21st, 2006 at 7:17am
I'm currently evaluating FlowChart .NET and one thing I didn't find until now. Is it possible to connect multiple links to a node/table to multiple anchor points?
Ex.: On top of the node (box), I'd like to connect a various number of links. But each should get a single anchor point (5 links = 5 anchor points, equally distributed). Is something like this possible, or do I have to code this, and is it possible to code this with reasonable effort?
Best regards,
Alex
Re: Multiple anchor points
Reply #1 - Nov 21st, 2006 at 8:01am
You might define the anchor points using the AnchorPattern class and the Node.AnchorPattern property:
AnchorPattern ap5;
private void Form1_Load(object sender, System.EventArgs e)
  fc.SnapToAnchor = SnapToAnchor.OnCreateOrModify;
  // define five incoming anchor points
  AnchorPointCollection points = new AnchorPointCollection();
  for (short i = 0; i < 5; i++)
    points.Add(new AnchorPoint((short)(10 + i * 20), 0,
     true, false, MarkStyle.Circle, Color.Blue));
  // and one outgoing
  points.Add(new AnchorPoint(50, 100, false, true));
  ap5 = new AnchorPattern(points);
  AnchorPattern.Register(ap5);
private void fc_InitializeBox(object sender, MindFusion.Diagramming.WinForms.BoxEventArgs e)
  // set the anchor points when users start to draw a new box
  e.Box.AnchorPattern = ap5;
private void fc_ValidateAnchorPoint(object sender, MindFusion.Diagramming.WinForms.AttachConfirmArgs e)
  // allow at most one arrow to connect to an anchor point
  if (numArrows(e.Node, e.AnchorIndex) > 0)
    e.Confirm = false;
private int numArrows(Node node, int anchorIndex)
  int total = 0;
  foreach (Arrow arrow in node.IncomingArrows)
    if (arrow.DestAnchor == anchorIndex)
     total++;
  return total;
Best regards,
Alex
Reply #2 - Nov 21st, 2006 at 8:17am
Thank you very much!
Finally found the correct Example  Smiley, but you were faster than me!
Very nice product!
