Normal Topic Error with Brushes after upgrade (Read 2685 times)
Christie
Dec 6th, 2006 at 12:54pm
I managed to solve most of my previous problems after the upgrade to 4.2.2, but the following error persist wherever I try to use any instance of Brush, for example:
Error
'SolidBrush' is ambiguous in the namespace 'MindFusion.Drawing'.
The following code:  boxTest.Brush = New MindFusion.Drawing.LinearGradientBrush(SandyBrown, Color.Beige)
results in this error:
Error 1 'LinearGradientBrush' is ambiguous in the namespace 'MindFusion.Drawing'.
I am using VS2005 (VB.Net)
Re: Error with Brushes after upgrade
Reply #1 - Dec 6th, 2006 at 1:49pm
Do you also use our Planner.NET control? Now both controls have MindFusion.Drawing namespaces. We are going to move the Brush classes to a separate dll in a few days, but until then you will have to use namespace aliases in order to resolve the Brush class references. E.g. select the flowchart.net.dll in Solution explorer, open the properties window, and in the Aliases line enter some namespace alias, say "fc". Now in the source code files where you access the flowchart API, add
"extern alias fc;"
to the top, and change the using directives so that they start with "fc::", e.g.
using fc::MindFusion.Diagramming.WinForms;
Now you will be able to differentiate between the Planner's and Flowchart's Brush classes through the "fc::" prefix.
We are moving common classes to a MindFusion.Shared.dll which will be used in both FlowChart.NET and Planner.NET, and aliases won't be needed when it's ready.
Christie
Reply #2 - Dec 6th, 2006 at 10:46pm
I am using Planner.Net as well...also, I am using FlowChart.Net and not FlowChartX, so I have posted this in the wrong forum..sorry
but could you please show me how to set the alias in VS2005 (VB.Net) as there is no alias field under properties for FlowChart.Net
Reply #3 - Dec 7th, 2006 at 5:59am
I can see aliases only in C# projects. I'll try to find a way to do it in VB.NET. If that’s not supported, I will email you a preview version of the shared dll.
