Hot Topic (More than 10 Replies) Question to Zoom functionality (Read 7286 times)
SJahr
Dec 8th, 2006 at 7:26am
i have a question to the zoom functionality of your FlowChart.NET control. At the moment zooming starts at the upper left corner of the visible part of my control. How can i realize that zooming starts at my mouse pointer position?
regards
Steffen
Re: Question to Zoom functionality
Reply #1 - Dec 8th, 2006 at 8:38am
It might be possible to do that using ZoomToRect. Zoom to a RectangleF centered around the mouse position, so that it is larger than the current visible area if you wish to zoom out, or smaller than it if you wish to zoom in.
You can get the document coordinates of the visible area and the mouse like this:
RectangleF visible = fc.ClientToDoc(fc.ClientRectangle);
PointF mousePos = fc.ClientToDoc(fc.ScreenToClient(MousePosition));
Then create a new RectangleF from [mousePos - visible.size / 2] to [mousePos + visible.size / 2], call its Inflate() method with a positive value to zoom out or a negative one to zoom in, and finally call the flowchart's ZoomToRect() method.
SJahr
Reply #2 - Dec 8th, 2006 at 9:51am
Sorry, but your suggestion doesn't work. My flowchart doesn't contain an definition for the method 'ScreenToClient'. I have the latest version of flowchart.NET
regards
Steffen
Reply #3 - Dec 8th, 2006 at 11:26am
Sorry, I meant PointToClient.
SJahr
Reply #4 - Dec 8th, 2006 at 11:47am
I have tried to implement the zooming on using the mouse wheel. But i have always problems with it. but i didn't see my error.
My zoom jumps over the screen, but didn't zoom to the mouse position...
Quote:
void flowChart_MouseWheel(object sender, MouseEventArgs e)
        RectangleF visible = flowChart.ClientToDoc(flowChart.ClientRectangle);
        PointF mousePos = flowChart.ClientToDoc(flowChart.PointToClient(MousePosition));
        RectangleF newRect = new RectangleF(mousePos.X- visible.Size.Width / 2, mousePos.Y - visible.Size.Height / 2, mousePos.X + visible.Size.Width / 2, mousePos.Y + visible.Size.Height / 2);
        if (e.Delta > 0)
           newRect.Inflate(1.5f, 1.5f);
        else
           newRect.Inflate(-1.5f, -1.5f);
        flowChart.ZoomToRect(newRect);
Reply #5 - Dec 8th, 2006 at 11:52am
The RectangleF constructor takes (x,y,width,height) arguments. Try that with visible.Size.Width and visible.Size.Height as values for the last two parameters.
Reply #6 - Dec 8th, 2006 at 11:56am
But maybe we use a wrong approach here. This will bring the location under the mouse point to the center of the control's visible area. And probably you want that point to remain at the same place while zooming in or out?
SJahr
Reply #7 - Dec 8th, 2006 at 11:58am
Excellent support. It works fine. Thank you.
regards
Steffen
liakix
Reply #8 - Jan 26th, 2012 at 12:58pm
Hello to everyone in the forum!
Well, 5 years after the last post on this thread i'm having exactly the issue described at the quoted text. Is there any solution to this?
Thanks in advance,
Aimilios
Reply #9 - Jan 26th, 2012 at 2:56pm
Try this if you need the diagram point at current mouse position to remain at the same position after zoom:
private void OnMouseWheel(object sender, MouseEventArgs e)
	PointF docPointAtMousePos = diagramView.ClientToDoc(e.Location);
	int factorToIncrese = e.Delta * SystemInformation.MouseWheelScrollLines / 120;
	diagramView.ZoomFactor += factorToIncrese;
	PointF newPointAtMousePos = diagramView.ClientToDoc(e.Location);
	diagramView.ScrollX -= newPointAtMousePos.X - docPointAtMousePos.X;
	diagramView.ScrollY -= newPointAtMousePos.Y - docPointAtMousePos.Y;
liakix
Reply #10 - Jan 27th, 2012 at 7:45am
Problem solved, it works like a charm!
Thanks Stoyo,
Aimilios
