Normal Topic ZoomToFit in 3D diagram (Read 2993 times)
Hamdy Ghanem
Jan 24th, 2012 at 1:54pm
I am trying to call ZoomToFit function for 3D diagram but it seems it is not working
How we do the same job ?
Julien_Dechene
Re: ZoomToFit in 3D diagram
Reply #1 - Jan 24th, 2012 at 2:47pm
What do you mean by not working ? Does it do partially what you want or it does nothing at all ?
Reply #2 - Jan 26th, 2012 at 11:54am
This version makes public some matrix and vector classes, with whose help you could fit nodes within the view as shown below.
https://mindfusion.eu/_beta/fcnet_matrix.zip
The method moves the camera backwards iteratively until all nodes fit. Our developer will try to implement something more precise for the next release.
void Fit3D()
	diagramView3D.PointCameraTo(CenterPoint());
	while (!Fits())
		MoveCameraForward(-1);
		diagramView3D.ResetProjection();
bool Fits()
	foreach (DiagramNode node in diagram.Nodes)
		Rectangle rect = diagramView3D.GetProjectionRect(node);
		if (!diagramView3D.ClientRectangle.Contains(rect))
			return false;
	return true;
Point3D CenterPoint()
	if (diagram.Nodes.Count == 0)
		return new Point3D();
	Point3D center = new Point3D();
		Point3D p = (Point3D)node.LayoutTraits[View3D.Position];
		center.X += p.X;
		center.Y += p.Y;
		center.Z += p.Z;
	center.X /= diagram.Nodes.Count;
	center.Y /= diagram.Nodes.Count;
	center.Z /= diagram.Nodes.Count;
	return center;
private void MoveCameraForward(float dz)
	Matrix3D cameraRotationMatrix = GetRotationMatrix();
	if (cameraRotationMatrix == null)
		return;
	Vector3D v = new Vector3D(0, 0, dz);
	Vector3D r = cameraRotationMatrix.Invert() * v;
	Point3D cameraPosition = diagramView3D.CameraPosition;
	cameraPosition.X += (float)r.X;
	cameraPosition.Y += (float)r.Y;
	cameraPosition.Z += (float)r.Z;
	diagramView3D.CameraPosition = cameraPosition;
Matrix3D GetRotationMatrix()
	Point3D cameraRotation = diagramView3D.CameraRotation;
	double[] t = new double[3];
	t[0] = (Math.PI / (180 / cameraRotation.X));
	t[1] = (Math.PI / (180 / cameraRotation.Y));
	t[2] = (Math.PI / (180 / cameraRotation.Z));
	return
		new Matrix3D(1, 0, 0, 0, Math.Cos(-t[0]), Math.Sin(-t[0]), 0, -Math.Sin(-t[0]), Math.Cos(-t[0])) *
		new Matrix3D(Math.Cos(-t[1]), 0, -Math.Sin(-t[1]), 0, 1, 0, Math.Sin(-t[1]), 0, Math.Cos(-t[1])) *
		new Matrix3D(Math.Cos(-t[2]), Math.Sin(-t[2]), 0, -Math.Sin(-t[2]), Math.Cos(-t[2]), 0, 0, 0, 1);
