Normal Topic VB.Net code for coloring cells and prob with darg (Read 3097 times)
bxsl
Jan 6th, 2007 at 11:11am
Do you have any VB.net code on how to color cells in a timetable? I would like to be able to set different times of the day in different colors, Also with the drag and drop demo if you have 2 or more contacts displayed and you try the drag when you drag a new item onto the control as you drag it over the contact it paints on all the contacts not just the one you hover over with the mouse
Re: VB.Net code for coloring cells and prob with d
Reply #1 - Jan 8th, 2007 at 6:06am
The 'Zones' sample demonstrates how to use custom drawing in order to paint different cells in the timetable in different colors. You can find this sample in the 'Samples/VB.NET' sub-folder of your installation directory or download it from the following link:
https://mindfusion.org/_samples/_sample_Zones2.zip
As for the 'Drag & Drop' sample, it might require minor modifications in order to work with grouped timetables. Here is a modified version of the sample:
https://mindfusion.org/_samples/_sample_DragDrop.zip
bxsl
Reply #2 - Jan 8th, 2007 at 9:35am
Do you have any vb code for how the coloring is done in the main demo that comes with the install? I like the way in this that you can still see the time lines, in the zones demo they are gone.
Reply #3 - Jan 8th, 2007 at 10:46am
Here is a fragment of the Calendar.Draw event handler body from the Demo application, translated in VB:
If e.Element = CustomDrawElements.TimetableCell Then
    ' Draw all workig cells in a custom fashion
    If e.Date.DayOfWeek <> DayOfWeek.Saturday And _
     e.Date.DayOfWeek <> DayOfWeek.Sunday Then
	  ' Check if this cell is selected
	  Dim d As DateTime = e.Date.Add(e.StartTime)
	  Dim selected As Boolean = Calendar1.Selection.Contains(d)
	  If TimeSpan.Compare(e.StartTime, TimeSpan.FromHours(Calendar1.TimetableSettings.WorkTimeEndHour)) < 0 And _
	   TimeSpan.Compare(e.EndTime, TimeSpan.FromHours(Calendar1.TimetableSettings.WorkTimeStartHour)) > 0 Then
		Dim brush As Brush = Nothing
		If selected Then
		    brush = New HatchBrush(HatchStyle.Percent50, _
		     Color.Goldenrod, Color.Yellow)
		Else
		     Color.Yellow, Color.White)
		    Dim bounds As Rectangle = e.Bounds
		    bounds.Inflate(-1, -1)
		    e.Graphics.FillRectangle(brush, bounds)
		    brush.Dispose()
		End If
	  End If
    End If
End If
The sample demonstrates how to preserve the cell lines during custom drawing.
