Normal Topic New item canceled event? (Read 2420 times)
bxsl
Jan 10th, 2007 at 12:54am
What event is raised if a user is creating a new item then press’s the esc key to cancel the creation? I have tried the itemModificationcanceled event but this didn't work. I would like to know if there is a way to do this.
Re: New item canceled event?
Reply #1 - Jan 10th, 2007 at 5:55am
It seems that there is no event fired when the item's in-place creation is canceled. We will add a new event to the control. Can you please remind me whether you use .NET Framework 1.1 or 2.0 so that I can send you the appropriate preliminary build through e-mail?
Thank you,
bxsl
Reply #2 - Jan 10th, 2007 at 7:49am
I use 2 thankyou
