Normal Topic Install problem with delphi2006 (Read 4698 times)
parkwonwoo
Open the Podbay Doors
HAL!
Feb 14th, 2007 at 12:30am
Install problem with delphi2006 .
I dont know How to install FCX to "Delphi Tool Palette".
Really difficult to istall it. --;
Is there any delphi install process manual?
Thanks.
OS: WinXP sp2&&RAD: Borland Delphi7, C++Builder6, JBuilder9&&FrameWork: VCL+Win32 or J2SE&&FCX: FCX 4.1.x
Re: Install problem with delphi2006
Reply #1 - Feb 14th, 2007 at 6:43am
We have never used Delphi 2006. I will download an evaluation copy to try that.
parkwonwoo
HAL!
Reply #2 - Feb 14th, 2007 at 11:10pm
Just unit Compiling is possible with delphi2006.
So, FCX Object is called and declared to delphi2006 project.
But Component Visualizing to Tool Palette is not easy to me.
So, Visual Drawing on the form is not possible.
Of course, I tell the Win32 and VCL Project environment, not the .NET Project.
Reply #3 - Feb 15th, 2007 at 5:57am
I have managed to add it to the palette:
- create a new Package project
- select Component \ Import component
- select ActiveX \ FlowChartX
- build the project
- select Component \ Install package and select the package you've just built
- the control will appear in the ActiveX page in the palette window
parkwonwoo
HAL!
Reply #4 - Feb 22nd, 2007 at 5:53am
Many Thanks !
