Normal Topic ShapeDesigner question (Read 2596 times)
nikulin_andrey
Feb 28th, 2007 at 3:27pm
There is not enough of ShapeDesigner documentation in demo version and I can't find how can I load a shape template back to the shape designer to edit it?
So I have created some shape. saved all info which I got from createShapeTemplate() method in db. But how to load it back into shape designer?
Re: ShapeDesigner question
Reply #1 - Feb 28th, 2007 at 4:47pm
You can assign the ShapeTemplate instance to the ShapeDesignerCtrl.Shape property. E.g. the \Samples\C#\ShapeDesigner example handles the ShapeSelected event of the shape list box like this:
private void shapeListBox1_ShapeSelected(object sender, ShapeEventArgs e)
	if (e.ShapeTemplate != null)
		shapeDesigner1.Shape = e.ShapeTemplate;
meriturva
Reply #2 - Mar 1st, 2007 at 8:02am
I don't find the shapeDesigner.Shape definition in MindFusion.Tools.ShapeDesignerCtrl.ShapeDesigner
I have the 4.2.2 demo version and i found the ShapeDesignerCtrl.dll into the root directory of the "FlowChart.NET Demo" directory not into the "Assemblies for .NET 2.0" directory.
The version of ShapeDesignerCtrl.dll is 1.0.2531.17748
am i wrong?
Reply #3 - Mar 1st, 2007 at 10:44am
The ShapeDesignerCtrl.Shape property is new for FlowChart.NET 4.3, which we have released a few days ago. The new version also contains a .NET 2.0 build of the ShapeDesigner control.
Reply #4 - Mar 1st, 2007 at 10:45am
You can already download the 4.3 demo version here -
https://mindfusion.eu/FCNetDemo.zip
