Normal Topic ShapeDesigner question 2 (Read 1968 times)
nikulin_andrey
Mar 5th, 2007 at 12:56pm
Hi Stoyo,
Why is not possible to insert outline element through context menu on shape designer?
What is the right way to add arc element as ouline?
Re: ShapeDesigner question 2
Reply #1 - Mar 5th, 2007 at 4:36pm
Hi Andrey,
You can use the Split Segment and Convert commands from the context menu shown when you right click a segment. I could not find a way to add an arc through the designer though... We will fix this in a couple of days and upload the updated designer source here.
Until then, you can insert an arc only by manually adding an entry in the shape library xml file. It should like
    <outline>
     <arc x="40" y="0" arc-width="20" arc-height="20" start="0" sweep="45" dash-style="Custom" width="-1" />
nikulin_andrey
Reply #2 - Mar 6th, 2007 at 8:06am
But what was a reasen to implement it like that?
Whay outline elements we can add by splitting and decoration elements we can add from context menu?
Reply #3 - Mar 6th, 2007 at 8:19am
I guess because the shape outline must be a single closed path, and the end points of each outline segment must coincide with the end points of its adjacent segments. The designer enforces this condition by only letting you split existing segments.
