Normal Topic Event on Arrow Creation? (Read 1592 times)
mattapayne
Mar 6th, 2007 at 7:55pm
I'm looking for a way to handle a user drawing an arrow from a node to another arrow. I don't need to join on the destination arrow, I just need to know when that particular series of events has occurred. Is there any way to achieve this?
Matt
Re: Event on Arrow Creation?
Reply #1 - Mar 6th, 2007 at 8:10pm
The "Ternary connections"  example shows something of that kind. It uses the AllowUnconnectedArrows property, which allows drawing an arrow to any point of the document, even if there isn't any node there. The ArrowCreated event handler checks whether there is another arrow at the point whether the new arrow is created by using the GetArrowAt method -
private void fc_ArrowCreated(object sender, MindFusion.Diagramming.WinForms.ArrowEventArgs e)
	Arrow a = e.Arrow;
	// if not connected to a real node
	if (a.Destination is DummyNode)
		PointF endPt = a.ControlPoints[a.ControlPoints.Count - 1];
		a.Locked = true;// so we can exclude it from the search
		Arrow trg = fc.GetArrowAt(endPt, 1, true);
		if (trg != null)
mattapayne
Reply #2 - Mar 6th, 2007 at 8:55pm
Thanks Stoyo, I'll look into that.
Matt
