Normal Topic Prevent routing from changeing arrow anchor (Read 4296 times)
darylp
Mar 15th, 2007 at 10:45am
Is it possible to prevent the auto routing to not move the orgin or destination anchor of the arrow. It is vital that the arrows stay at the anchor points that the user set.
Re: Prevent routing from changeing arrow anchor
Reply #1 - Mar 15th, 2007 at 11:42am
Setting FlowChart.RoutingOptions.Anchoring = Keep should do that.
Daniel
Reply #2 - Jun 14th, 2007 at 9:22am
I have the same problem with tables and your solution does not do it.
Reply #3 - Jun 14th, 2007 at 10:13am
Could you post here the table property values and AnchorPattern definition?
Daniel
Reply #4 - Jun 14th, 2007 at 11:03am
Hmm. Strange. With
flowChart.RoutingOptions.Anchoring = Anchoring.Reassign
it works???, although the arrows are rerouted a little bit strange. They go straight down (or up)  from the anchor point for a short distance and then away from the table (only some do that).
Anyway, I'm not sure what you need, so here's what I set specifically:
table.ColumnCount = 3;
table.Scrollable = false;
table.EnabledHandles = Handles.Move;
table.CellFrameStyle = CellFrameStyle.None;
table.HandlesStyle = HandlesStyle.MoveOnly;
table.Columns[0].Width = 4;
table.Columns[1].Width = 22;
table.Columns[2].Width = 4;
table.RowCount = 3;
table[0, 0].RowSpan = 3;
table[1, 0].RowSpan = 3;
table.Rows[0].Height = 6;
table.Rows[1].Height = 6;
table.Rows[2].Height = 6;
table.Rows[0].AnchorPattern = new AnchorPattern(new AnchorPoint[]
                           new AnchorPoint(0, 50, true, false, Color.Black, 0),
                           new AnchorPoint(100, 50, false,true, Color.Green, 2)
table.Rows[0].AnchorPattern.Points[0].MarkStyle = MarkStyle.Circle;
table.Rows[0].AnchorPattern.Points[1].MarkStyle = MarkStyle.Circle;
table.Rows[1].AnchorPattern = new AnchorPattern(new AnchorPoint[]
                           new AnchorPoint(100, 50, false, true, Color.Blue, 2)
table.Rows[1].AnchorPattern.Points[0].MarkStyle = MarkStyle.Circle;
table.Rows[2].AnchorPattern = new AnchorPattern(new AnchorPoint[]
                           new AnchorPoint(100, 50, false, true, Color.Red, 2)
table.Rows[2].AnchorPattern.Points[0].MarkStyle = MarkStyle.Circle;
I'm also using a custom behavior, I took from another thread here, that you answered.
http://mindfusion.org/cgi/Forum/YaBB.pl?board=fcnet_disc;action=display;num=1153...
I also have a completly different problem. Nice shadows and emboss from EffectsProvider work fine with Boxes, but not with Tables. Is this on purpose?
Daniel
Reply #5 - Jun 14th, 2007 at 12:00pm
Unfortunately those effects are available only for boxes at this time.
What TableLinkStyle are you using?
Daniel
Reply #6 - Jun 14th, 2007 at 12:58pm
It's the default value
FlowChart.TableLinkstyle = Rows
This is what it looks like:
Reply #7 - Jun 14th, 2007 at 1:11pm
I have tried this using the FCDemo \ ERD sample and could not see any problems. Could you email me a saved diagram file with several tables?
« Last Edit: Jun 14th, 2007 at 5:24pm by Stoyo »
Reply #8 - Jun 15th, 2007 at 4:52am
I've loaded the file you have emailed me into the FCDemo, and used the Route All Arrows command from the menu. The result looks OK to me -
so, try using the same RoutingOptions values as the ones from the FCDemo property grid.
