Normal Topic Table double click event (Read 1312 times)
pelion
May 15th, 2007 at 11:30pm
I need a double click event on a table, howver the TableDblClick event appears only to fire when the table header is clicked, not the table rows.
Any ideas on how I can implement this when any part of the table is clicked?
Cheers
JC
Re: Table double click event
Reply #1 - May 16th, 2007 at 5:45am
If you handle TableCellDblClicked, it will be raised when the table is clicked anywhere but in the caption area. So you can use that event to detect clicks on the table rows. I think that if there isn't any event handler attached to TableCellDblClicked, the control will raise TableDblClicked instead, even for clicks on the rows.
Cheers,
« Last Edit: May 17th, 2007 at 5:56am by Stoyo »
pelion
Reply #2 - May 17th, 2007 at 12:29am
Cheers,
I ended handling the double click on the Chart and doing a .GetTableAt function, which works just as well.
Thanks again for your help
