Normal Topic JavaScript Reference Missing! (Read 3459 times)
f_zaker
May 28th, 2007 at 11:49am
please tell me where can I find a good refrence for FlowChartX activeX control?!!!
I want to use it in a asp.net page.
Re: JavaScript Reference Missing!
Reply #1 - May 28th, 2007 at 11:59am
We now offer a native ASP.NET control:
https://mindfusion.org/NetDiagramTrial.zip
It supports more browsers and OSes than FlowChartX does.
If you prefer to use FlowChartX, you could see how to load it in a web page and call its methods from JavaScript here (take a look at the demo pages' source code):
http://www.mind-fusion.com/demo_std_page1.htm
The online demo loads an instance of the FlowchartX standard edition. If you want to use the Pro edition, change the classid attribute to the following:
classid="CLSID:F025BF4E-4081-4c02-86E6-6602AEE846F6"
f_zaker
Reply #2 - May 28th, 2007 at 12:04pm
as I told, I need a JavaScript reference! so if exist, please give me its address.
thanks.
f_zaker
Reply #3 - May 28th, 2007 at 12:14pm
Stoyo wrote on May 28th, 2007 at 11:59am:
I need a control that can work with .Net 1.1 not 2.0
Reply #4 - May 28th, 2007 at 12:34pm
We don't have any reference other than the developer's guide, available form the FlowChartX submenu under the Windows Start menu. The method prototypes there are listed in language independent manner, you will need to translate them to JavaScript yourself.
