Hot Topic (More than 10 Replies) setEnabled() for Overview has no effect (Read 7410 times)
ymoran00
Jun 20th, 2007 at 12:56pm
I'm trying to disable the Overview component.
I've used setEnabled(false) - but it works the same.
Isn't there a way to disable it? At least to make the Rectangle static?
Yoav
Re: setEnabled() for Overview has no effect
Reply #1 - Jun 20th, 2007 at 3:59pm
What do you mean by disabling it - making it ignore all mouse input?
ymoran00
Reply #2 - Jun 21st, 2007 at 3:50am
Yup. This sounds like it. Anything that will cause the Overview to be unchanged.
Reply #3 - Jun 21st, 2007 at 6:31am
I have sent you a private message with links to the licensed jar and updated Overview.java.
ymoran00
Reply #4 - Jun 21st, 2007 at 10:39am
Something has happenned in the new Jar.
I have used AnnelLayout until now with average layout timing of 0.5 second. Now each time I run it - it takes more than 5 secondseach time!
Is that the fix for the distances between nodes? If so - it's a problem. That's too much for an increase in timing.
Reply #5 - Jun 21st, 2007 at 12:04pm
That's not the final version of the layout algorithm; we are still testing some new layout evaluation methods. Anyway could you email me some typical diagram of yours so we can test the layout with it?
ymoran00
Reply #6 - Jun 24th, 2007 at 8:03am
I've saved the FlowChart and sent it to the support email. Hope it's right.
Yoav
ymoran00
Reply #7 - Jun 24th, 2007 at 9:10am
If it isn't working, here's a short description:
It's a graph with 8 pairs of nodes (8 instances of 2 nodes connected) and 2 triples of nodes (2 instances of 3 nodes connected). That's it.
Reply #8 - Jun 25th, 2007 at 7:33am
Is this the same graph that was arranged for 0.5 seconds?
ymoran00
Reply #9 - Jun 25th, 2007 at 7:37am
Yup. I'm using an older version of Jdiagram, and it still is.
Reply #10 - Jun 25th, 2007 at 8:15am
Ok, I have uploaded an updated licensed .jar - use the link from the last private message to download it. It should handle the node sizes correctly without being much slower.
ymoran00
Reply #11 - Jun 25th, 2007 at 12:42pm
I'll give it a test run on the following days.
Thanks!
Yoav
