Normal Topic Export as .png file resolution (Read 2797 times)
Patrick Guerin
Dec 16th, 2014 at 5:01pm
Does anybody know how to export JDiagram Graph in PNG in high resolution ?  Actually, I use the function java.awt.image.BufferedImage image = diagram.createImage(); to export the image of the graph.  But the output resolution seem to be link with the width and height of the document Graph.  I was thinking the function (setImageDpiX(dpi)) would help, but it's not the case.  Thanks for help.
Re: Export as .png file resolution
Reply #1 - Dec 16th, 2014 at 5:59pm
By resolution do you mean image size in pixels (width x height ), or logical pixel density? For density check the solution here:
http://stackoverflow.com/questions/321736/how-to-set-dpi-information-in-an-image
You can export more pixels per diagram unit using the following code, and combine it with PNG serialization code from topic above:
private void testPngExport()
	double dpiScale = 4;
	double unitScale = Utilities.convert(
		1, diagram.getMeasureUnit(), GraphicsUnit.Point);
	double scale = unitScale * dpiScale;
	// create bitmap image
	BufferedImage img = new BufferedImage(
		(int)(diagram.getBounds().getWidth() * scale),
		(int)(diagram.getBounds().getHeight() * scale),
		BufferedImage.TYPE_INT_ARGB);
	// draw the diagram
	Graphics2D graphics = img.createGraphics();
	graphics.scale(scale, scale);
	diagram.draw(
		graphics,
		new RenderOptions(),
		diagram.getBounds());
	File file = new File("test.png");
	try
		ImageIO.write(img, "png", file);
	catch (IOException e)
		// TODO Auto-generated catch block
		e.printStackTrace();
Patrick Guerin
Reply #2 - Dec 16th, 2014 at 8:02pm
Wow !  It works perfectly...  Thank you very much...   Smiley
