Normal Topic Using ScriptHelper with the DiagramApplet (Read 3846 times)
JR
Dec 4th, 2013 at 1:16pm
Firstly, I am working with the version 3.4.
We want to code 2 things with the ScriptHelper class in javascript :
1°) A Customized DashStyle for a pen like this :
Code (Java)
	private Pen formeLien (VgLien lie) {
		Pen stylo = new Pen();
		DashStyle d = null;
		if (lie.getReel().equals("1")) {
			d = new DashStyle (new float []{3,3}, 0);
			stylo.setDashStyle(d);
		} else if (lie.getReel().equals("2")) {
			d = new DashStyle (new float []{2,2}, 0);
		} else if (lie.getReel().equals("3")) {
			d = new DashStyle (new float []{4,2,4}, 0);
		if (lie.getCritique() == 2) {
			stylo.setWidth(3);
		} else if (grapheImage) {
			stylo.setWidth(1);
		} else {
			stylo.setWidth(0);
		stylo.setColor(invertColor (lie.getCouleur()));
		return stylo;
2°) An AnchorPattern with specifics AnchorPoints like this :
Code (Java)
AnchorPattern apat = new AnchorPattern(new AnchorPoint[] {new AnchorPoint(5, 0),new AnchorPoint(20, 0),
				new AnchorPoint(45, 0),new AnchorPoint(50, 0),new AnchorPoint(55, 0),
				new AnchorPoint(80, 0),new AnchorPoint(95, 0),
				new AnchorPoint(30, 100),new AnchorPoint(45, 100),new AnchorPoint(50, 100),
				new AnchorPoint(55, 100),new AnchorPoint(70, 100)}, "Process");
Is it possible with the ScriptHelper class, have we to use another class or is it impossible ?
Regards
Juan
JR
Re: Using ScriptHelper with the DiagramApplet
Reply #1 - Dec 4th, 2013 at 4:15pm
We have found the solution for the AnchorPoint problem.
We have to do an AnchorPattern.getPoints().add(.. ) like the code below
Code (Javascript)
var scrhlp = DiagramApplet.getScriptHelper();
var anchors = scrhlp.anchorPatternFromId ("Process");
anchors.getPoints().add(scrhlp.createAnchorPoint (5,0));
anchors.getPoints().add(scrhlp.createAnchorPoint (20,0));
anchors.getPoints().add(scrhlp.createAnchorPoint (40,0));
anchors.getPoints().add(scrhlp.createAnchorPoint (50,0));
anchors.getPoints().add(scrhlp.createAnchorPoint (55,0));
anchors.getPoints().add(scrhlp.createAnchorPoint (80,0));
anchors.getPoints().add(scrhlp.createAnchorPoint (95,0));
anchors.getPoints().add(scrhlp.createAnchorPoint (30,100));
anchors.getPoints().add(scrhlp.createAnchorPoint (45,100));
anchors.getPoints().add(scrhlp.createAnchorPoint (50,100));
anchors.getPoints().add(scrhlp.createAnchorPoint (55,100));
anchors.getPoints().add(scrhlp.createAnchorPoint (70,100));
We are still looking for the DashStyle problem.
Regards
Juan
Reply #2 - Dec 4th, 2013 at 5:33pm
It might be possible using the solution shown here:
http://stackoverflow.com/questions/1295882/is-it-possible-to-create-arbitrary-ja...
and Java reflection classes such as:
http://docs.oracle.com/javase/7/docs/api/java/lang/reflect/Array.html
If that does not work, you could override DiagramApplet and add your helper methods to the custom applet, then use it on the page instead of the standard one.
JR
Reply #3 - Dec 5th, 2013 at 10:44am
We have override the DiagramApplet and it works Smiley.
Juan
