Normal Topic itemSelected & mouseClicked event (Read 1958 times)
koosala
Java Happens
Jul 4th, 2007 at 3:13am
When an Box is selected for the first time, itemSelected event is fired, and then a mouseClicked event is fired.
If the selected box is clicked again, itemSelected event is not fired and only mouseClicked event is fired.
When an arrow is selected for the first time, it acts similar to the box, both the events are fired.
When the arrow is selected for a second time (not at the control points), the itemSelected event and mouseClicked event are both fired again. At a control point, only the mouseClicked is raised.
Would this be a bug or the expected behavior?
I am relying on a combination of these events to do some operation.
Re: itemSelected & mouseClicked event
Reply #1 - Jul 4th, 2007 at 6:51am
The Selected event should be raised only when the selection state changes, so clicking the box for a second time should not raise it. If it is raised on the second click for an arrow, the control might be first deselecting the arrow and later selecting it again, which probably is not the right behavior.
