Normal Topic one continuous block? (Read 3267 times)
Xray
Jul 4th, 2007 at 1:13pm
hi,
How i config the planner control (SingleMonth) to let the user select just one! continuous block of dates?
Xray
Re: one continuous block?
Reply #1 - Jul 4th, 2007 at 1:18pm
You can select continuous block of dates interactively by clicking on the first date and dragging with the mouse towards the last date. In this case you have to ensure that Calendar.Selection.AllowMultiple is set to State.Enabled.
You can select the block programmatically by calling the Calendar.Selection.Set method and passing the first and the last dates of the block as arguments.
Xray
Reply #2 - Jul 4th, 2007 at 1:30pm
thx for the quick response!
selecting by clicking on the first date and dragging with the mouse towards the last date works ok, but if the user then use the cntr key he can also select outer day's.
i want the user can select one range so i can generate a report with a start en end date.Smiley ex:01/01/2007 - 30/03/2007.
Reply #3 - Jul 5th, 2007 at 4:40am
We will implement a new feature, preventing users from selecting more than one range. I will let you know when it is ready.
Reply #4 - Jul 5th, 2007 at 7:45am
Here is a new preliminary version of Planner.NET:
https://mindfusion.org/_planner/_Planner.NET_422pre_trial.zip
The Selection class now exposes a new property - Continuous, which when set to State.Enabled, prevents users from selecting multiple date ranges at the same time.
Xray
Reply #5 - Jul 5th, 2007 at 11:02am
Works perfect!
Fantastic support!
thx,
Xray
