Normal Topic Table to Node List (Read 2775 times)
hollywood
Total Noob
Table to Node List
Jul 10th, 2007 at 6:05pm
Is it possible to add a table to my Node list so that I can drag it onto my pallet and have it draw the table instead of a box? I also want to wire it up to the property grid. Can this be done? (Yes, I am a total noob. Wink )
Re: Table to Node List
Reply #1 - Jul 10th, 2007 at 6:30pm
Check the Flowcharter example. It shows how to create a custom listbox that displays Flowchart.NET objects. Just call the FlowChart.CreateTable method once, before or after the box shapes are added. Let me know if you need help on that 8)
The same example shows how to display item properties in the PropertyGrid control and how to implement drag-and-drop form the listbox.
hollywood
Total Noob
Reply #2 - Jul 10th, 2007 at 6:40pm
I will run through that example tonight. Thanks for pointing me in the right direction.
hollywood
Total Noob
Reply #3 - Jul 11th, 2007 at 1:43pm
I got the tables to draw. Thanks so much for your prompt help. I haven't gotten to the properties yet, but I am sure it will be no problem.  Cheesy
hollywood
Total Noob
Reply #4 - Jul 12th, 2007 at 5:56pm
Just as I suspected! It was easy cheesy. Grin
Reply #5 - Jul 13th, 2007 at 4:32am
