Normal Topic Print Dialogue (Read 3093 times)
srlevitt
Print Dialogue
Jul 20th, 2007 at 11:21am
I have a fussy user who is really hung up about the page range in the print dialogue. Why does the range go from 1..100 when there are only one or two pages in the document?
Thanks.
Re: Print Dialogue
Reply #1 - Jul 20th, 2007 at 1:18pm
You can use your own print dialog:
PrintDialog dlg = new PrintDialog();
dlg.Document = new PrintDocument();
dlg.Document.PrinterSettings.FromPage = 1;
dlg.Document.PrinterSettings.ToPage = 100;
if (dlg.ShowDialog(this) == DialogResult.OK)
     fc.Print(dlg.Document);
srlevitt
Re: Print Dialogue
Reply #2 - Jul 20th, 2007 at 1:50pm
Thats certainly good, but is there a property somewhere in the flow chart which tells me how many pages the print will run to, i.e. the last page number?
Re: Print Dialogue
Reply #3 - Jul 21st, 2007 at 12:47pm
Set docRect = FlowChart.GetContentRect(true, true) to find out the size of the printable area. The A4 paper size is 210 mm by 297 mm. Subtract the margin size from the paper size and assign the result to pageRect. Make sure all values used in the calculation are measured in the same unit. Finally
int xPages = (int)Math.Ceiling(docRect.Width / pageRect.Width);
int yPages = (int)Math.Ceiling(docRect.Height / pageRect.Height);
The last page number is xPages * yPages.
srlevitt
Re: Print Dialogue
Reply #4 - Jul 21st, 2007 at 4:24pm
Stoyan,
your help, as always is spot-on. Thanks. Grin
Steve.
