Normal Topic problem with LaneGrid (Read 1277 times)
Lili
Aug 7th, 2007 at 6:18am
Hi. Is there any way to add new custom properties for LaneGrid? When I try to inherit from the MindFusion.Diagramming.WinForms.Lanes.Grid class I get „The type 'MindFusion.Diagramming.WinForms.Lanes.Grid' has no constructors defined” error.
Thanks.
Re: problem with LaneGrid
Reply #1 - Aug 7th, 2007 at 10:55am
Currently that's not possible. Even if you were able to define a custom grid class, there is no way to make Flowchart.NET use it instead of the standard grid.
