Hot Topic (More than 10 Replies) Exception Creating a Box (Read 15258 times)
Re: Exception Creating a Box
Reply #15 - Aug 16th, 2007 at 1:29pm
We'll test this on other systems here tomorrow. It doesn't crash on mine, neither in release nor debug mode. Are you running any other applications that use GDI+ at the same time as the test project?
alan_wood
Reply #16 - Aug 16th, 2007 at 3:59pm
I typically have Outlook, MSDEV and whatever is in my system tray running.
alan_wood
Reply #17 - Aug 17th, 2007 at 2:23pm
System Tray Has:
McAfee Virus Scanner & Personal Firewall (Firewall service is disabled)
Google Talk
Google Updater
Dell Support
Windows Defender
QuickTime
I've turned all of those off and closed all applications and I still have the issue.
I've sent via email a new version of the code (which allows the dialog to be closed) and a detailed MFC dump (using the MFC trace utility) of the problem.
I hope that helps narrow down what could be wrong!
Reply #18 - Aug 18th, 2007 at 9:29am
Could you enable the "When the exception is thrown: break into the debugger" option for all exceptions from the dialog displayed by the \debug\exceptions menu command; then copy here the contents of the call-stack debug window when the exception happens?
alan_wood
Reply #19 - Aug 20th, 2007 at 10:48am
With all exceptions breaking into the debugger when thrown, the call stack is identical:
Main Thread:
[quote]
GdiPlus.dll!_GdipCreateFont@20()  + 0xa8 bytes
FlowChartPro.dll!10081426()
[Frames below may be incorrect and/or missing, no symbols loaded for FlowChartPro.dll]
FlowChartPro.dll!10081ab4()
ntdll.dll!_RtlGetVersion@4()  + 0x74 bytes
FlowChartPro.dll!100836c5()
FlowChartPro.dll!100f2412()
FlowChartPro.dll!100f242f()
FlowChartPro.dll!100f245a()
FlowChartPro.dll!100f028e()
FlowChartPro.dll!100894a8()
FlowChartPro.dll!1010544b()
FlowChartPro.dll!10064e59()
user32.dll!7e4184b2()
FlowChartPro.dll!10041c0f()
FlowChartPro.dll!10041b1d()
FlowChartPro.dll!1004bce0()
FlowChartPro.dll!1004bbc6()
FlowChartPro.dll!1004b9e5()
FlowChartPro.dll!100593f8()
user32.dll!7e418734()
user32.dll!7e418816()
user32.dll!7e41b4c0()
user32.dll!7e4184fc()
user32.dll!7e41b50c()
ntdll.dll!_KiUserCallbackDispatcher@12()  + 0x13 bytes
user32.dll!7e4194d2()
user32.dll!7e41b530()
user32.dll!7e4196c7()
mfc80d.dll!AfxInternalPumpMessage()  Line 183
C++
mfc80d.dll!CWinThread::PumpMessage()  Line 896
C++
mfc80d.dll!CWinThread::Run()  Line 625 + 0xd bytes
C++
mfc80d.dll!CWinApp::Run()  Line 894
C++
mfc80d.dll!AfxWinMain(HINSTANCE__ * hInstance=0x00400000, HINSTANCE__ * hPrevInstance=0x00000000, char * lpCmdLine=0x00151f15, int nCmdShow=0x00000001)  Line 47 + 0xd bytes
C++
TestFlowChartX Creation.exe!WinMain(HINSTANCE__ * hInstance=0x00400000, HINSTANCE__ * hPrevInstance=0x00000000, char * lpCmdLine=0x00151f15, int nCmdShow=0x00000001)  Line 33
C++
TestFlowChartX Creation.exe!__tmainCRTStartup()  Line 589 + 0x35 bytes
C
TestFlowChartX Creation.exe!WinMainCRTStartup()  Line 414
C
kernel32.dll!7c816fd7()
[/quote]
Background Thread:
[quote]
ntdll.dll!_KiFastSystemCallRet@0()
ntdll.dll!_ZwWaitForMultipleObjects@20()  + 0xc bytes
kernel32.dll!7c8094e2()
[Frames below may be incorrect and/or missing, no symbols loaded for kernel32.dll]
user32.dll!7e4195f9()
user32.dll!7e41c96c()
user32.dll!7e4196a8()
GdiPlus.dll!BackgroundThreadProc()  + 0x59 bytes
kernel32.dll!7c80b683()
[/quote]
Reply #20 - Aug 20th, 2007 at 11:44am
Please try that with the debug build of flowchart.dll -
https://mindfusion.org/_temp/FlowChartPro.zip
It should display a more informative call stack.
