Normal Topic Editing of Arrow names & passing arrow referen (Read 4158 times)
Samun
Aug 15th, 2007 at 8:45pm
I wanted to provide the users the possibility of editing the arrow names, but arrows don't have the .BeginInplaceEdit of boxes, so I thought about opening a window with the arrow reference when the user double-clicks on it, change the text (and possibly some other arrow properties) in the form and then update the Flowchart with the supplied arrow reference.
The code is as follows:
    Private Sub AxFlowChart1_ArrowDblClicked(ByVal sender As Object, ByVal e As AxFLOWCHARTLib._IFlowChartEvents_ArrowDblClickedEvent) Handles AxFlowChart1.ArrowDblClicked
        'Open Arrow edition screen
       Dim ArrForm As New ArrowForm
       ArrForm.MdiParent = Main
       ArrowForm.ArrowLine = Me.AxFlowChart1.ActiveArrow
       ArrForm.Show()
    End Sub
This is supposed to pass the reference to a variable declared as:
    Public ArrowLine As FLOWCHARTLib.arrow
The text is then supposed to change with the following event:
    Private Sub txtName_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles txtName.TextChanged
       If Not (ArrowLine Is Nothing) Then
           ArrowLine.Text = txtName.Text
       End If
    End Sub
However, the "ArrowLine" is always nothing, so the reference is apparently not passed to the other form.
What am I doing wrong?
Re: Editing of Arrow names & passing arrow ref
Reply #1 - Aug 16th, 2007 at 6:38am
Use the e.Arrow event argument to access the arrow that has been double clicked.
Samun
Reply #2 - Aug 16th, 2007 at 4:32pm
Hello, Stoyan
Thank you for the response, but it does not work either. It did not work either when I tried to pass the arrow reference using ".Findarrow" and the tag ID. For some mysterious reason I am unable to pass on an arrow reference from the Diagram form to the form that has to edit the arrow data.
However, if I make the call the other way round, i.e., from the "child" form ArrForm that has to edit the arrow data using ".Findarrow" then it DOES work:
               ArrowLine = Main.CurrentDiagram.AxFlowChart1.FindArrow(m_ArrowId)
It has me left totally mystified.... given that with this latter solution I have been able to find a workaround it's OK, but if you find where the problem is in my code I'd like to hear about it...
Thanks for your help.
Reply #3 - Aug 17th, 2007 at 4:05am
--> ArrowForm.ArrowLine = Me.AxFlowChart1.ActiveArrow
ArrForm.Show()
You are setting the ArrowLine member of one form (ArrowForm, which is the default form instance created by VB.NET), but then displaying a different form (ArrForm).
Samun
Reply #4 - Aug 17th, 2007 at 2:31pm
There is only one diagram, I am not trying to send arrows between different diagrams or display it in different forms.
"Arrowform" is simply a new form so as to be able to edit the arrow name, as I cannot do it on the diagram itself. It does not contain a diagram of its own.
"Arrowline" is supposed to be simply a reference to the arrow so that when I update the name of the arrow in the Arrowform  form I can call back the original diagram in the original form (using Arrowline.Text) and update directly the corresponding arrow.
Eventually I got the workaround to get a reference to the corresponding arrow using:
This allows me to change the arrow name in the original diagram while I am still editing the name in the Arrform arrow name editing form.
What surprises me is that I cannot pass the object from the original form TO the arrow editing form for the callback, but I CAN get the callback reference FROM the arrow editing form.... very mysterious....
Thank you anyhow for your help
Reply #5 - Aug 18th, 2007 at 9:01am
I think you are using two different forms in these three lines of code:
ArrForm.Show()
One form is ArrForm, and the other form is ArrowForm. You are setting ArrowForm.ArrowLine, but then calling ArrForm.Show(), thus displaying
a form where ArrowLine is not set.
Samun
Reply #6 - Aug 19th, 2007 at 1:56pm
Ooops... now that was a really stupid mistake... Roll Eyes
In any case it has demonstrated (again) that your customer service is first-class.
Thank you very much, Stoyo!
Reply #7 - Aug 20th, 2007 at 5:36am
