Normal Topic background problem (Read 2990 times)
wangqaa
background problem
Jun 6th, 2007 at 9:49am
Hi~
I want to creat a background which like a big box on the buttom of many boxes and arrows.
I am now trying creating a box on the botton.
But some unexpected problem happened.
The upper arrow are not routing like before.
There two way I think to reslove this problem:
1. How to create background in specific range not all field?
2. How to avoid affect routing when I create
a big Box on the botton?
need help
thanks you!
Re: background problem
Reply #1 - Jun 6th, 2007 at 9:51am
Set boxBox.Obstacle = false.
wangqaa
Reply #2 - Jun 6th, 2007 at 10:00am
I have tried it , but it doesn't work. Sad
wangqaa
Reply #3 - Jun 6th, 2007 at 10:06am
After I create abox on the bottom and set that box Obstacle = false.
The other boxes also become like Obstacle = false.
The oringinal are Obstacle = true.
I don't know why effect others..
Reply #4 - Jun 6th, 2007 at 10:07am
Have you set it before routing the arrows?
wangqaa
Reply #5 - Jun 6th, 2007 at 10:20am
I set it after routing the arrows.
Reply #6 - Jun 6th, 2007 at 10:33am
That's too late. Set Obstacle = false before routing the arrows, or call FlowChart.RouteAllArrows() again after setting it.
wangqaa
Reply #7 - Jun 6th, 2007 at 11:22pm
Hi~
  you point out the problem ~
  ok la!
  thanks a lot !  Tongue
