Normal Topic GetNodeAt() question (Read 2318 times)
Alex
Aug 27th, 2007 at 8:32am
is it possible to get another GetNodeAt()-Method?
I would like to implement a functionality, so that the user can't move Nodes over other nodes. I managed it to implement it for Drag&Drop from the Shapelist.
Currently I'm trying to use the GetNodeat(PointF, treshold)-Method to check the nodes during Drag&Drop.
But this function doesn't allow to eliminate the selected Node. Otherwise if I use GetNodeAt(PointF, excludeLocked, excludeSelected) I loose the treshold.
Or is there such a thing, that the diagram doesn't allow more than one Node in one spot?
Best regards,
Alex
Re: GetNodeAt() question
Reply #1 - Aug 28th, 2007 at 11:07am
We have added a GetNodeAt(PointF, excludeLocked, excludeSelected, threshold) overloaded method to the latest beta build:
https://mindfusion.eu/FCNetBeta.zip
Alex
Reply #2 - Aug 29th, 2007 at 6:17am
Works perfectly!
Thanks again and again and again and ...
Your support is awesome!
Alex
Reply #3 - Aug 29th, 2007 at 6:43am
