Normal Topic RoundRectangle problem (Read 2031 times)
Alex
Aug 29th, 2007 at 9:43am
when I use the following code
public static ElementTemplate[] elements = new ElementTemplate[]
  new RoundRectangle(0, 0, 100, 100, 6)
I get an error that this constructor has not 5 arguments. I copied the code from the ShapeDesigner.
Alex
Re: RoundRectangle problem
Reply #1 - Aug 29th, 2007 at 10:52am
Did exactly that code appear in the designer? You must use the RoundRectangleTemplate class from the MindFusion.Diagramming namespace. There is a RoundRectangle class in the MindFusion.Tools.ShapeDesignerCtrl namespace, but you can't use it in shape definitions. Anyway replacing RoundRectangle with RoundRectangleTemplate should fix the error.
Alex
Reply #2 - Aug 30th, 2007 at 3:48am
Yes this is the code from the ShapeDesigner:
// C# ShapeTemplate definition
   new Shape(
 null, FillMode.Winding,   "test" );
Alex
