Normal Topic Arrows - Limiting them (Read 1403 times)
GizmoHd
Sep 18th, 2007 at 12:27pm
I want to be able to limit the arrows two and from an object.
For example, BOX A is allowed to connect to only ONE additional Box. And Only One Box can connect To BOX A...
Basically, each item should allow one connection in.. and only one connection out.  Is there a simple method of accomplishing this task?
Thanks in advance
Re: Arrows - Limiting them
Reply #1 - Sep 18th, 2007 at 12:42pm
You can do that by handling the LinkCreating and LinkModifying validation events. E.g. this disables drawing an outgoing link from a node when the node already has at least one link:
private void diagram_LinkCreating(object sender, MindFusion.Diagramming.LinkValidationEventArgs e)
     if (e.Origin.OutgoingLinks.Count > 0)
           e.CancelDrag();// or set e.Cancel = true;
The difference between calling e.CancelDrag() and setting e.Cancel = true is that the former immediately stops the drawing operation, whereas the latter changes the mouse cursor to a stop icon but allows the user to continue drawing the link to a different location.
GizmoHd
Reply #2 - Sep 18th, 2007 at 12:51pm
Thank you..
Much easier than I thought it would be.. Smiley
