Normal Topic Boxes overlap (Read 1032 times)
alesdario
Boxes overlap
Sep 18th, 2007 at 2:01pm
Hi stoyan.
In my diagram often heppen that two boxes are overlapped. When i clik on the overlapped area, i want that always the same box will selected. There is a way to give a priority to a Box i want select?
Tanks.
Re: Boxes overlap
Reply #1 - Sep 18th, 2007 at 3:49pm
Hi Alesdario,
Assign a bigger ZIndex value to the box that has a higher priority. If you can determine that only at the time when the boxes are clicked, call GetNodesAt to find all nodes at the mouse position, and select one of them programmatically.
