Normal Topic In resource view, Hightlight the selected row (Read 3863 times)
ironmonkey
Aug 29th, 2007 at 2:11pm
I need to hightlight the entire row when user selects an appointment or the resource, so he knows which row is being selected and can copy or swap the appointments. What method or property can achieve this ?
Re: In resource view, Hightlight the selected row
Reply #1 - Aug 30th, 2007 at 5:47am
Try the following solution:
First, enable custom drawing of the resource row headers, by setting Calendar.CustomDraw to CustomDrawElements.ResourceViewRowHeader. Then handle the Calendar.Draw event. The event handler can have an implementation similar to the following:
private void calendar_Draw(object sender, CustomDrawArgs e)
	if (e.Element == CustomDrawElements.ResourceViewRowHeader)
		Contact contact = e.Resource as Contact;
		ItemCollection c = calendar.Schedule.GetAllItems(
			DateTime.MinValue, DateTime.MaxValue, contact);
		bool selected = false;
		foreach (Item i in c)
			if (calendar.ItemSelection.Contains(i))
				selected = true;
				break;
		if (selected)
			Rectangle b = e.Bounds;
			b.Width -= 1;
			b.Height -= 1;
			e.Graphics.DrawRectangle(Pens.Red, b);
The above code presumes that the resources in the calendar are contacts. If you are using different resources, perform the necessary modifications. The code draws a red border around the header of the resource row containing selected items. If you need some other kind of visualization, you may have to custom-draw another CustomDrawElements, such as ResourceViewCell.
madrider
Reply #2 - Sep 4th, 2007 at 9:34pm
When I try that code, I get a null reference for contact and the count for c is 0. Why is that?
Resource is a valid object but contact is null.
Reply #3 - Sep 5th, 2007 at 6:25am
This can happen if you are not grouping by contacts (e.g. you are grouping by locations or general resources). In this case you will have to cast to the appropriate type. For example, if you are grouping by location, you will have to modify the code in the following way:
Location location = e.Resource as Location;
ironmonkey
Reply #4 - Sep 7th, 2007 at 9:23pm
Hi, Meppy:
I had another issue in Resource view, for a resource if he has request time off, I need to show the time period ( like from 8AM to 4PM), but user still can add appointment( schedule ) during that period. How can I just paint the background as red?
Reply #5 - Sep 10th, 2007 at 5:12am
You can use a similar approach. You need to set CustomDrawElements.ResourceViewCell as a value of the Calendar.CustomDraw property and modify the contents of the Calendar.Draw event handler in a way similar to the following:
if (e.Element == CustomDrawElements.ResourceViewCell)
	if (e.Date.TimeOfDay.Hours >= 8 &&
		e.Date.TimeOfDay.Hours <= 16)
		b.X += 1;
		b.Width -= 1;
		b.Height -= 1;
		Brush brush = new SolidBrush(Color.FromArgb(200, Color.Red));
		e.Graphics.FillRectangle(brush, b);
		brush.Dispose();
Hope this helps.
ironmonkey
Reply #6 - Sep 11th, 2007 at 3:59pm
It works. Thanks!
